let
VARIABLE
VALUE
The let statement creates a local variable and assigns a value to it.
variable – is the name of the variable that you want to create.
value – calculates the value that will be placed into the variable.
This statement works just like an assignment, but the destination of the assignment is automatically created as a local variable. For example, this statement creates a local variable named x and assigns the value 23 to it.
let x=23
The value can be any data type, for example text like this:
let userName="Bob"
Note: This statement is identical to the assignlocal statement, but let uses an equal sign between the variable name and the value, instead of a comma.
Note: Local variables should never be used in a form.
