assign
DESTINATION
VALUE
The assign statement assigns a value to a field or variable.
This statement has two  parameters:
destination – is the name of the field or variable that you want to store the value into.
value – is the value to be stored.
The assign statement assigns a value to a field or variable. For example, this statement assigns the value John Smith to the field or variable Name.
assign Name,"John Smith"
The more common shortcut for assignment is to use the = symbol, like this:
Name = "John Smith"
The two statements above are identical and interchangeable, you can use either one as you like.
| 10.0 | New | New in this version |
