showline
The showline statement forces Panorama to redisplay the current record in all windows in the current database.
This statement tells Panorama to redisplay all of the data in the current record in every open window of the current database. Use this command after the noshow command when you have only modified the current record. ShowLine does not turn the display back on. To do that you must use the endnoshow statement.
Here is an example that clears the current record in the database, but doesn’t display anything until it is completely finished.
noshow
field (array( dbinfo("fields",""),1,cr())) // goto first field
loop
clearcell
right
until info("stopped")
showline
endnoshow
- endshowlater -- resumes the immediate display of text and graphics after it has been deferred with the showlater statement.
- fontcharacters( -- returns a string (text) containing all of the characters supported by the specified font.
- fontinfo( -- returns a dictionary with information about a specified font.
- hide -- temporarily disables the output of text and graphics.
- measuretext( -- returns the size of a string of text in a particular font and size.
- setbannericon -- sets the icon on the right side of the toolbar banner.
- setbannermessage -- sets the text in the toolbar banner to an arbitrary message.
- setbannerprogressbar -- displays progress in the toolbar banner.
- show -- resumes the output of text and graphics after it has been disabled and then forces Panorama to redisplay all windows in the current database.
- showlater -- defers the display of text and graphics until the procedure is finished.
- showother -- forces Panorama to update some data on the screen.
- showpage -- forces Panorama to redisplay all windows in the current database.
