alertdeletecancel
TEXT
The alertdeletecancel statement displays a modal alert window with a message and two buttons: Delete and Cancel.
This statement displays a modal alert window with a message and two buttons: Delete and Cancel. (Delete is the default.) Afterwards, the name of the button that was clicked can be accessed with the info(“dialogtrigger”) function.
alertdeletecancel "Do you want to delete?"
if info("dialogtrigger") = "Cancel"
stop
