gettextokcancel
PROMPT
INPUT
The gettextokcancel statement displays a modal dialog that asks the user to enter an item of text.
prompt – is a message that will be displayed in the dialog. This message should explain what the user needs to enter.
input – is a field or variable where the user’s input will be placed. If this is a field, it should be a text field. The input field or variable should be assigned a value before the gettext statement is used. This value will be displayed as the default value in the dialog.
This statement displays a dialog with a single area for text entry. The user may enter something and press Ok, or they may press the Cancel button. The program can determine what button was pressed by using the info(“dialogtrigger”) statement.
This example asks the user to enter an area code, then selects all phone numbers in that area code. The default area code is 909.
local whatArea
whatArea="909"
gettextokcancel "Area code:",whatArea
if info("dialogtrigger") match "Ok"
select Phone match "("+whatArea+")*"
- activegrid -- manages the operation of a grid that controls a series of options.
- analyzedialog -- opens the standard Analyze dialog.
- closeallasyncprogresswindows -- closes any asynchronous progress windows.
- columnstatsdialog -- opens the standard Column Stats dialog.
- customdialog -- customizes the appearance of the gettext and getscrap dialogs.
- editfavoritesdialog -- handles the Favorites button in a dialog.
- favoritedatabasedialog -- opens the standard Favorite Databases dialog.
- favoritesbutton -- handles the *Favorites* button in a dialog.
- getscrap -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- getscrapok -- will display a dialog with a text entry area. The entered text is placed in the clipboard.
- gettextdialog -- displays a configurable modal dialog that asks the user to enter an item of text.
- importdatabasedialog -- opens the standard Import Database dialog.
- joindialog -- opens the standard Join Database dialog.
- morphalldialog -- opens the standard MorphAll dialog.
- morphdialog -- opens the standard Morph dialog.
- popupsharingmenu -- pops up a menu for the toolbar sharing icon.
- rundialog -- uses a form as a template to display a modal dialog window. The statement supervises the operation of the dialog until it is closed.
- rundialogmenus -- enables custom menus in a modal dialog.
- selectduplicatesdialog -- opens the standard Select Duplicates dialog.
- sortdialog -- opens the standard *Sort* dialog.
- supergetpassword -- will display a dialog with a text entry area for a password.
- supergettext -- will display a dialog with a text entry area.
10.0 | New | This function is new in this release. |
