select
CONDITION
The select statement makes visible only those records for the active database for which the specified condition is true.
condition – is a Boolean formula (a formula with a true/false result).
This statement is used to make visible all records for which a specified Boolean formula is true. All records not matching the Boolean formula will become invisible. If a subset of records has already been selected from the database, select will examine all records looking for a match.
This example selects all records for John Smith.
select Customer = "John Smith"
This example selects all records for Votes over 12000.
select Votes > 12000
This example selects all records on or after January 1 2010.
select Shipped > date("1/1/2010")
In this example the info(“empty”) function is used to test to see if no records were selected for the date entered.
local ADate
gettext "Enter date ex. 12/31/95",ADAte
select ProcessDate = date(ADate)
if info("empty")
beep
message "No records match this date: "+ADate
stop
Note: If no records match the Boolean formula, all records will be selected (you can use the safeselect statement if you don’t want this to happen). Panorama doesn’t allow the entire database to be invisible. See Handling Empty Selections in Code to learn about how to handle failed selections in your code.
10.0 | Updated | Carried over from Panorama 6.0, but no longer displays a notification if the selection fails, even if this is the last statement in the procedure. |
