htmldatamerge
HTML
OPTIONS
TEMPLATE
The htmldatamerge statement uses a template to generate HTML you want from a database.
html – field or variable that the output HTML will be placed into.
options – list of options that modify how the HTML is generated from the template.
template – controls how the data is placed into the HTML output by this statement. The template consists of a section of text with HTML tags and Panorama formulas embedded in it. The formulas are embedded in between curly braces { and }. You may embed as many formulas as you want – either one big formula or lots of little ones. However, each formula must produce text as an output, so any numbers must be converted to text with the str( or pattern( functions.
This statement uses a template to generate HTML you want from a database. Typical applications include lists, formatted tables, and even JavaScript (usually to initialize a JavaScript array). Here is a simple example that creates an HTML list:
htmldatamerge cgiHTML,{},
  |||<li>{str(seq())} <b>{Hotel}</b>, {pattern(Rate,"$#,.##") } ({Phone})|||
This template has four formulas embedded in it:
{str(seq())} ☞ Merges an automatic sequence number: 1, 2, 3 etc.
{Hotel} ☞ Merges the contents of the Hotel field
{pattern(Rate,"$#,.##") } ☞ Merges the Rate field, converted to text
{Phone} ☞ Merges the Phone field
The output HTML looks something like this:
Using the browser’s View Source command we can examine the actual HTML generated by the procedure. Notice that the htmldatamerge statement was smart enough to add <ul> and </ul> tags at the beginning and end of the list. If your layout begins with <li> it will automatically add these tags. If your layout begins with <tr> it will automatically add <table> and </table> tags. (You can override these defaults and specify your own header and footer, see the next section.)
<ul>
<li>1 <b>Aspen Square</b>, $85.00 (925-1000)
<li>2 <b>Best Western Aspenalt Lodge</b>, $52.00 (927-3191)
<li>3 <b>Boomerang Lodge</b>, $72.00 (925-3416)
<li>4 <b>Innsbruck Sports Motel</b>, $74.00 (925-2980)
<li>5 <b>Limelite Lodge</b>, $62.00 (925-3025)
<li>6 <b>Sands Motel</b>, $22.00 (366-3581)
<li>7 <b>The Molly Gibson Lodge</b>, $75.00 (925-2580)
<li>8 <b>Ullr Lodge</b>, $48.00 (769-7146)
<li>9 <b>Hotel Jerome</b>, $295.00 (920-1000)
<li>10 <b>International Hotel</b>, $129.50 (555-9876)
<li>11 <b>Snowflake Inn</b>, $59.00 (925-3221)
</ul>
Here is a modified version of the previous procedure:
  |||<li><font face="verdana" size=-2> <b>{Hotel}</b>,
    {pattern(Rate,"$#,.##")} ({Phone})<p>
    {?(Description="","",Description+"<p>")}</font>|||
This procedure uses the ?( function to merge in the description (if any). We’ve also changed the HTML tags to render the list using extra small Verdana font.
You can customize the HTML produced by the htmldatamerge statement with the options parameter. The basic options are header= and footer=. These options allow you to define additional HTML that will automatically be placed at the beginning and end of the generated HTML. (Of course you could also do this with a formula in your procedure.) For example, if you wanted to center the entire page, you could use
header="<center>"
footer="</center>"
Here is a modified version of our sample procedure that uses the header= and footer= options to center the output:
  {header="<center><hr>" footer="</center>"},
  |||<h2>{Hotel}</h2>
    {pattern(Rate,"$#,.##")}<br>{Phone}<hr>|||
And here’s the first few records generated by this procedure:
Aspen Square
$85.00
925-1000
$52.00
927-3191
Boomerang Lodge
$72.00
925-3416
$74.00
925-2980
You can also specify color= and colorpattern= options. For a complete description of these options see Table Background Colors in HTMLDataTable. To use the color options you must embed the tag <color> somewhere in your template. This tag will be replaced by the actual rendered color specified by the options. However, the <color> tag must not be in one of the embedded formulas -— it should only be in the HTML portion of the template. For example, the <color> tag can be embedded in a <td> tag to specify the background color of table cells.
      color="EEEEFF"
      color="EEFFEE"
      colorpattern="12"
      header={<center><table border=0 width=450 cellpadding=4 cellspacing=4><tr><td align=center bgcolor="999999"><font size=+2 face="Helvetica" color="FFFFFF">&nbsp;<br><b>Hotel Listings</b><br>&nbsp;</font></td>}
      footer={</table></center>}|||,
  |||<tr><td bgcolor="<color>"> <font face="Verdana" size=-2> <b>{Hotel}</b>, {pattern(Rate,"$#,.##") } ({Phone})<p>
    {?(Description="","",Description+"<p>")}</font></td></tr>|||
The result is a nice, formatted table listing each hotel, with alternating background colors for each hotel:
Hotel Listings
Aspen Square, $85.00 (925-1000)
The center of activities in downtown Aspen. Luxury condominiums with kitchens, fireplaces, color TV, private balconies, daily maid service, underground parking, heated pool, Jacuzzi and saunas.
Best Western Aspenalt Lodge, $52.00 (927-3191)
Riverfront rooms (on the Frying Pan River) just 16 miles from Aspen/Snowmass. Seven restaurants nearby. Deluxe Continental Breakfast.
Boomerang Lodge, $72.00 (925-3416)
Nicely landscaped grounds. Some fireplaces. Balconies or patios. Cable TV, radios, phones. Kitchens and laundry. Sauna, whirlpool, heated year round pool.
Innsbruck Sports Motel, $74.00 (925-2980)
Imaginative decor, some refrigerators. Cable TV, phones, year-round heated pool. No pets.
Limelite Lodge, $62.00 (925-3025)
Quality accommodations at reasonable rates in the heart of Aspen. Next to beautiful Wagner Park, 1 block to Wheeler Opera House, unique shopping and many fine restaruants. Heated Pools, HBO, in-room refrigerators. Guest laundry on premises.
Sands Motel, $22.00 (366-3581)
This is a test!
The Molly Gibson Lodge, $75.00 (925-2580)
Beautiful contemporary rooms and suites, including Honeymoon and Anniversary suites. Jacuzzis, Fireplaces, kitchens, balconies and patios. Remote control TV's and VCR's. Complimentary Continental Breakfast. Mountain Views. Two swimming pools and whirlpools.
Ullr Lodge, $48.00 (769-7146)
Traditional European style lodging in Aspen. Family owned and operated. Indoor and outdoor whirlpools. Sauna. Walking distance to Music Tent and Aspen Institute.
Hotel Jerome, $295.00 (920-1000)
Restored 1889 hotel furnished with exceptional antiques & reproductions of Victorian style. Refrigerators, cable tv, movies, radio, phones. No pets. Reviewed by Jõrg Wëlstrûm © 1985.
International Hotel, $129.50 (555-9876)
A great hotel in downtown Denver.
Snowflake Inn, $59.00 (925-3221)
In Room: Cable TV. Coffee Maker. Hair Dryer. Iron & Ironing Board. Safe. Data Line. Kitchen.
Linking a Table or List with a Detail Form
A list can include links to detail pages, just like a table. For more information on setting up this type of link see Linking Individual Table Rows to Detail Pages in HTMLDataTable. Be sure to include <link> and </link> tags in the template for displaying the list.
