runningtotal
The runningtotal statement calculates the running total for the current field.
The runningtotal statement starts at the top of the database and adds up the numbers in the current field. As it scans the database it fills the field with the running total, destroying the original data in the process.
This example calculates the balance after each transaction in a checkbook database.
field Balance
formulafill Credit-Debit
runningtotal
- @calculations --
- runmodifyfill -- runs the .ModifyFill procedure (if it exists).
- slidedata -- slides the columns at and to the right of the current column.
