getclick
VERTICAL
HORIZONTAL
The getclick statement returns the location of the mouse in global coordinates (coordinates from the top left corner of the screen).
vertical – field or variable in which the vertical co-ordinate will be placed.
horizontal – field or variable in which the horizontal co-ordinate will be placed
This statement is used to capture coordinates of the most recent mouse click. It is intended that this statement be used in a procedure that is triggered by a button on a form (or any form object that triggers a procedure).
This example checks to see if the mouse was clicked more than 5 points away from the previous mouse click.
fileglobal mouseV,mouseH
local newV,newH
define mouseV,0
define mouseH,0
getclick newV,newH
if abs(newV-mouseV)>5 or abs(newH-mouseH)>5
message "Clicked far away"
mouseV=newV // new click becomes old for next time
mouseH=newH
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
