speedcopy
START
END
FROM
The speedcopy statement copies multiple adjacent fields from a record in one database to a record in another.
start – is the first field to be replaced in the current database. The field name must be surrounded with quotes, for example: "City"
, not City
end – is the last field to be replaced in the current database. This field must be to the right of the start field in the data sheet. The field name must be surrounded with quotes, for example: "Zip"
, not Zip
from – is the field in the second database that corresponds to the start field in the current database. The field name must be surrounded with quotes, for example: "City"
, not City
This statement is designed to be used in combination with a lookup( function. First you lookup, then you copy. The speedcopy will copy additional data from the record that was located by the lookup( function. The speedcopy statement is much easier to write than multiple lookups.
For this example, assume that you have two databases, one named Customer and another named Organizer. Both have fields name Address, City, State and Zip. The example below will quickly look up a customer from the Customer database and copy their address into the Organizer database (which is the currently active database).
Address=lookup( "Customers",Company,Company,Address,"",0)
if Address <> ""
speedcopy "City","State","Zip"
Here is the same procedure but written without using the speedcopy statement.
Address=lookup("Customers",Company,Company,Address,"",0)
City=lookup("Customers",Company,Company,City,"",0)
State=lookup("Customers",Company,Company,State,"",0)
Zip=lookup("Customers",Company,Company,Zip,"",0)
Note: Starting with Panorama X, there is another way to do this using the lookupmoredata( function.
City=lookupmoredata(City,"")
State=lookupmoredata(State,"")
Zip=lookupmoredata(Zip,"")
Unlike using speedcopy, the lookupmoredata( technique doesn’t require that the fields be in the same order in the two databases. If they are in the same order, it’s probably simpler to use speedcopy.
- related( -- searches a database for a record in a related database that matches the current record in the current database based a relational specification (based on one or more key fields or formulas in each database), then uses a formula to return other information from the same record. This is similar to the lookup( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- relatedarray( -- builds an Text Array by scanning a database and creating an array element for every record that matches a relational specification (based on one or more key fields or formulas). This is similar to the arraybuild( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- relatedrecordid( -- returns the record id of a record in a related database that matches the current record in the current database based on a relational specification.
- Relational Workshop -- tool that assists in composing relational lookup(, superlookup(, lookupall( and arraybuild( functions.
10.0 | Updated | Carried over from Panorama 6.0, but works differently internally so that it no longer has the possibility of corrupting the data if the database fields don't match up exactly. |
