The tweakobject statement tweaks the dimensions of an object (or multiple objects).
This statement has three parameters:object – object name or id number.
transform – type of transformation to make to the rectangle. See the rectangletweak) function for the complete list of available transforms.
value – the value used for transforming the rectangle. Usually this is in points, but when the * prefix is used, it is a multiplication factor.
This statement tweaks the dimensions of an object using one or more rectangletweak( transformations. This example
tweakobject "Go Button","+y",20
You can apply multiple transformations to an object, like this:
tweakobject "Go Button","+y",20,"+x",100
If you supply a carriage return delimited array as the first parameter, you can apply the same transformation to multiple objects at a time. This example will move both buttons down by 16 points.
tweakobject commatocr("Go Button,Stop Button","+y",16
See the rectangletweak( function to learn about the various transformations that can be performed, including x, y, top, left, right, bottom, height, width and size.
| Version | Status | Notes |
| 10.2 | Updated | New in this version. |
