recompile
DATABASE
ERRORS
The recompile statement recompiles all procedures in a database.
database – The database whose procedures are to be recompiled, or “” for the current database.
errors – field or variable to receive a list of errors, if any.
This statement recompiles all procedures in a database.
- loadallprocedures -- loads all the procedures from a dictionary into the current database.
If a procedure doesn't exist it will be created.
