webformrecordid
PAGE
FIELDS
The webformrecordid statement adds a RECORD_ID hidden field to the HTML of a web form.
page – text of the HTML page. The text must contain a <form>
tag.
fields – one or more fields to be used as the key. If this parameter is ""
or omitted, the standard record ID will be used as the key (this is recommended).
This statement adds a RECORD_ID
hidden field to the HTML of a web form. The recommended technique is to use the standard record ID as the key.
webformrecordid cgiHTML
For compatibility with legacy applications, you can specify one or more explicit key fields.
webformrecordid cgiHTML,First,Last
If multiple fields are specified, they will be combined into one composite key.
10.2 | No Change | Carried over from Panorama 6.0. |
