alertnoyes
TEXT
The alertnoyes statement displays a modal alert window with a message and two buttons: No and Yes.
The alertyesno statement is similar to the message statement but instead of a single Ok button, both No and Yes buttons are displayed (No is the default.) Afterwards, the name of the button that was clicked can be accessed with the info(“dialogtrigger”) function.
alertnoyes "Do you want to continue?"
if info("dialogtrigger") = "No"
stop
