The summaryselectoriginalformula statement returns the formula that will select the original data associated with a summary table row.
This statement has four parameters:summaryinfo – is the name of variable that contains the summary specifications.
row – is the crosstab row that was summary on (1-N).
formula – variable to receive the formula.
database – variable to receive the name of the original database.
This statement returns the formula that will select the original data associated with a summary table row. You can use this to select the original data in the original database, or pass it to another text list or matrix to display the subset in that object.
This example will display the data corresponding to the current summary cell in the original database.
let clickedRow = info("matrixrow")
local selectionFormula,originalDatabase
summaryselectoriginalformula _summaryInfo,clickedRow,selectionFormula,originalDatabase
topdatawindow originalDatabase
if selectionFormula=""
selectall
else
execute "select "+selectionFormula
10.1 | New | New in this version. |
