copycell
The copycell statement copies the contents of the current field onto the clipboard,
replacing anything previously on the clipboard.
This statement copies the data from any type of field to the clipboard. This statement will only affect the currently active field (or cell).
Note: When you copy from a date-type field the date will transcribe to the clipboard in the format of MM/DD/YYYY regardless of the date field’s established output pattern.
