folderinfo
FOLDER
INFO
The folderinfo statement calculates the total size of a folder, and the number of files in the folder.
folder – path of folder
info – field or variable to where result will be place. The result is a dictionary with two items of information: 1) COUNT: # of files in folder, and 2) SIZE: total size of files in folder
This statement calculates the total size of a folder, and the number of files in the folder. This example displays the number of files in the Pictures folder, and the average size of each picture.
local fstats
folderinfo "~/Pictures",fstats
let pictureCount = getdictionaryvalue(fstats,"COUNT")
let totalPictureSize = getdictionaryvalue(fstats,"SIZE")
message "You have "+
pictureCount+" pictures (average size "+
bytepattern(totalPictureSize/pictureCount)+"."
