setbannerprogressbar
VALUE
DATABASE
The setbannerprogressbar statement displays progress in the toolbar banner.
value – is the progress value, from 0 to 1. For example 0.5 indicates that the current task is half complete.
database – is the database where the progress is to be displayed. This parameter is optional, if omitted or empty, the current database is used.
setbannerprogressbar 0.6
Note: The progress bar will appear in all data windows associated with the current database, not just the current window. You can also specify that the progress bar be displayed in a different database, like this:
setbannerprogressbar 0.4,"Checkbook"
- endshowlater -- resumes the immediate display of text and graphics after it has been deferred with the showlater statement.
- fontcharacters( -- returns a string (text) containing all of the characters supported by the specified font.
- fontinfo( -- returns a dictionary with information about a specified font.
- hide -- temporarily disables the output of text and graphics.
- measuretext( -- returns the size of a string of text in a particular font and size.
- setbannericon -- sets the icon on the right side of the toolbar banner.
- setbannermessage -- sets the text in the toolbar banner to an arbitrary message.
- show -- resumes the output of text and graphics after it has been disabled and then forces Panorama to redisplay all windows in the current database.
- showlater -- defers the display of text and graphics until the procedure is finished.
- showline -- forces Panorama to redisplay the current record in all windows in the current database.
- showother -- forces Panorama to update some data on the screen.
- showpage -- forces Panorama to redisplay all windows in the current database.
