listwebtemplates
DATABASE
RESULT
The listwebtemplates statement retrieves a list of web templates in the specified database, if any.
database – name of the database to search, or “” for the current database. The specified database must be open.
result – name of the field or variable the result should be placed into.
This statement retrieves a list of web templates in the specified database, if any. This example displays a list of templates in the current database.
local templateList
listwebtemplates "", templateList
message templateList
An alternate method for retrieving the list of templates is to use the listwebtemplates( function.
10.2 | Updated | Carried over from Panorama 6.0, but now stores the template in the form itself, and allows a database to be specified. |
