The deleterecchildrenwarn statement warns you before deleting the current record from the active database and all the records in another database that have a value in the key field that is equal to the key value.
This statement has three parameters:database – Name of database containing the “child” records.
keyfield – Name of the field you want to search in.
keyvalue – Value in records to be deleted.
This statement warns you before deleting the current record from the active database and all the records in another database that have a value in the key field that is equal to the key value.
This example warns, then deletes all the records from the My Contacts database that have a name in the Organization field that matches the value in the Company field in the current record, then it deletes the current record itself.
DeleteRecChildWarn "My Contacts", "Organization", Company
In other words, it deletes the company from both the current database and the My Contacts database.
