expand
The expand statement reveals the next level of collapsed detail records associated with the currently active summary record.
This statement reveals any collapsed detail records associated with the currently active summary record. If there is more than one level of collapsed detail, only the next level will be revealed (see expandall if you want to reveal all detail records, right down to data records).
This example goes to the last record in the database and, if it is a summary record, expands it to the next level below that summary record’s level.
lastrecord
expand
This example uses the collapse, expand, and expandall statements in a procedure to calculate percentages of Balance values for each data record associated with a specific summary 1 record for that group.
local BalTotal
field GLCategory
groupup
field Balance
total
outlinelevel 1
firstrecord
field Percentage
loop
if info("summary") =1
BalTotal = Balance
expand
formulafill (Balance/BalTotal)*100
collapse
downrecord
until info("eof") or info("summary") >1
lastrecord
fill Percentage
fill "100"
Percentage = zeroblank(0)
expandall
- analyzedialog -- opens the standard Analyze dialog.
- average -- calculates averages and sub-averages for the selected records in the current field.
- collapse -- hides the detail records associated with the currently active summary record.
- collapsetosummary -- collapses to the next higher summary level.
- count -- counts all non-empty data cells for the current field.
- expandall -- reveals all collapsed detail records associated with the currently active summary record.
- groupdown -- divides the database into groups, with a summary record at the end of each group. The groups are arranged in descending order (high to low).
- groupup -- divides the database into groups, with a summary record at the end of each group. The groups are arranged in ascending order (low to high).
- maximum -- calculates the maximum and sub-maximums for the current field.
- minimum -- calculates the minimum and sub-minimums for the current field.
- removeallsummaries -- removes all summary records.
- removedetail -- removes data records from the current database, leaving only summary records. It can also delete low level summary records, leaving only higher levels.
- removesummaries -- removes summary records from the current database.
- total -- calculates totals and subtotals for the current field.
