channelcatalog
FILES
The channelcatalog statement creates a list of all channel databases (including the path for each database).
files – field or variable where the result will be placed. Each line contains the file path and file name.
This statement creates a list of all channel databases (including the path for each database). This statement is intended for internal use by ProVUE, you should not ever need to call it in normal databases.
