posturl
VARIABLE
URL
ITEM
VALUE
The posturl statement loads a resource from the internet, with form data.
variable – is the name of the variable into which you wish to place the downloaded resource (usually text).
url – is the address of the resource to be loaded, for example "http://www.apple.com".
item – is the name of a form item expected by the server. Each name parameter must be paired with a value parameter (see below), you can have as many item/value pairs as the server calls for.
value – is the value of a form item.
This statement loads a resource from the internet, with form data. In this example, two values are posted, Name and Email.
local webPage
posturl webPage,"http://www.somesite.com/register",
    "Name","John Smith",
    "Email","jsmith@xyzmail.com"
displaydata webPage
This function returns whatever data the server responds with, usually HTML text.
Note: If you need more control over loading the resource, use the url( function instead.
Note: The posturl statement is synchronous. This means that Panorama stops in its tracks until the communication is complete, so you should avoid this function if possible and use urltask( instead.
10.0UpdatedCarried over from Panorama 6.0, but now can return binary data as well as text.
