procedureinsertformname
TEXT
The procedureinsertformname statement inserts a form name into a procedure, adding quotes.
text – form name to insert. (Note: The statement does not check that the text is actually a valid form name.)
This statement inserts a form name into a procedure, adding quotes.
procedureinsertformname "End of Year Report"
Note: This statement examines the text where the procedure name is about to be inserted for context. If there are quotes around the insertion spot, it will not add quotes. If there is an opening quote before the insertion spot, it will not add quotes and it will automatically add the appropriate closing quote mark.
