setfieldnames
NAMES
The setfieldnames statement changes the names of all database fields at once.
names – is a tab separated list of the new field names.
This statement changes the names of all database fields at once. This example sets the field names to the contents of the first record of the database.
firstrecord
setfieldnames exportline()
deleterecord
If the names array contains more names than there are fields, the extra names are ignored. If the names array contains fewer names than there are fields, the names of the extra fields will be left unchanged. If an element of the list is empty, the corresponding field name will be left unchanged.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
