lockedrecordlist
LIST
The lockedrecordlist statement returns a list of records locked in the current database.
list – field or variable to hold the list of locked records.
This statement returns the number of records locked in the current database, and also returns a list of those records (listed by record ID number). This statement has one parameter, the name of a field or variable to receive the list. The result will be formatted like this:
Ok: 2 records locked
378
864
This procedure displays the number of records locked in the current database.
local locks
lockedrecordlist locks
message firstline(locks)[4,-1]
- Web Cookies -- web cookies.
