settagdata
PAGE
PREFIX
SUFFIX
DATA
SEP
The settagdata statement changes the contents of a tag.
This statement has five parameters:
page – text that may contain tag (must be a field or variable).
prefix – opening tag.
suffix – closing tag.
data – new text for tag contents.
sep – optional separator if we need to add this tag to page.
This statement changes the contents of a tag.
For example, suppose a variable named Page contains this text within it.
<NAME>Mark Wilson</NAME>
To change this name to John Smith, use this code.
settagdata Page,"<NAME>","</NAME>","John Smith"
What if there wasn’t already a <NAME></NAME>
tag pair? In that case, a new tag pair will be added at the end of the text in the variable. If you want to make sure this new tag pair is on a new line, add a separator parameter like this:
settagdata Page,"<NAME>","</NAME>","John Smith",cr()
- gettaglocations -- locates all matching tags within some text.
- setxtagvalue -- changes the contents of a tag.
- tagcount( -- counts the number of times a specified tag (usually an HTML tag) appears in the text. See Tag Parsing for more information on HTML tags.
- tagdata( -- extracts the body of the specified tag (usually an HTML tag) in the text. See Tag Parsing for more information on HTML tags.
- tagend( -- returns the ending position of the specified tag (usually an HTML tag) in the text.
- tagnumber( -- checks to see if a specified position is inside of a tag (usually an HTML tag).
- tagparameter( -- extracts the value of a tag parameter embedded in some text, where the tag parameter takes the form *name=value*.
- tagstart( -- returns the starting position of the specified tag (usually an HTML tag) in the text.
- tagstrip( -- removes tags (usually HTML tags) from within a piece of text.
