insertbelowcarriagereturn
The insertbelowcarriagereturn statement inserts a new record below the current record and moves to the first column.
This statement adds a new record below the current record, and moves to the first (leftmost) column in the database. This is identical to the action performed by pressing the Carriage Return key (hence the name). (Note: The InsertBelow statement is similar, but does not move to the first column.)
- copycell -- copies the contents of the current field onto the clipboard,
replacing anything previously on the clipboard.
10.0 | New | New in this version, but performs the same action as performed by the InsertBelow statement in Panorama 6.0 and earlier versions. |
