rudemessage
MESSAGE
The rudemessage statement displays a message alert.
message – message that appears in the alert.
This statement displays a message alert. In previous versions of Panorama this alert would be larger than the normal message alert, but now the regular message statement will automatically expand to accomodate any amount of text, so this statement is now redundant. It is still included for compatibility with existing databases that are already using it.
Here is an example of how this statement is used:
rudemessage "You could put a lot of text here!"
