The setautonumber statement changes the automatically generated number for the next record that will be added to database. This allows you to generate numbers out of sequence, or to start the sequence at a specific value.
This statement has one parameter:number – is the number that should be assigned to the next record that is created. This must be an integer.
Panorama can automatically number new records as they are added to the database. This statement allows a procedure to change what the next number will be. This example skips autonumbering ahead by 100:
setautonumber getautonumber()+100
