deleteselectedobjects
The deleteselectedobjects statement deletes selected objects from a form.
This statement deletes selected objects from a form. Usually a procedure will use the SelectObjects statement to select the objects before deleting them. This example deletes all push button objects from a form.
selectobjects objectinfo("class") contains "PushButton"
