fieldtypes
DATABASE
RESULT
The fieldtypes statement returns a carriage return delimited array with list of fields and field data types.
database – Database that you want list of field types for, or “” for current database.
result – Field or variable for result.
This statement returns a carriage return delimited array with a list of the fields and field data types. Each line returned is in this format:
FIELDNAME tab() FIELDTYPE[numericfieldtype]
Here is an example of how this could be used:
local fieldInfo
FieldTypes "Checkbook",fieldInfo
This will fill the fieldInfo variable with something like this:
Check¬NUMERIC[6]
Date¬DATE[4]
PayTo¬TEXT[0]
Debit¬NUMERIC[5]
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
