arrayrelocate
ARRAY
SEPARATOR
POSITION
NEWPOSITION
COUNT
The arrayrelocate statement moves one or more items in a text array to a new position.
This statement has five parameters:
array – the array to be reordered.
separator – the separator character.
position – the original position of the first item you want to move.
newposition – the new position of the first item you want to move.
count – the number of items to move. This parameter is optional, if omitted, one item will be moved.
This statement moves one or more items in a text array to a new position.
local ocell,ncell
dragwithinmatrix ocell,ncell
arrayrelocate colors,",", ocell,ncell
For additional explanation and examples, see the arrayrelocate( function.
