splitfielddialog
The splitfielddialog statement opens the standard Split Field dialog.
This statement opens the standard Split Field dialog, just as if the user had clicked on the Split Field tool icon or chosen Split Field from the Fields menu.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
