noyes
TEXT
The noyes statement displays a modal alert window with a message and two buttons: No and Yes.
This statement displays a modal alert window with a message and two buttons: No and Yes. (No is the default.) Afterwards, the name of the button that was clicked will be in the clipboard.
noyes "Do you want to continue?"
if clipboard() = "No"
stop
Note: This statement is retained for compatibility with legacy databases. For new applications, the alertnoyes statement, which does not disturb the clipboard, is recommended.
