webserverinfo
ITEM
RESULT
The webserverinfo statement retrieves additional information about the web server and the current browser request.
item – specifies what additional information should be retrieved.
result – field or variable where the retrieved information will be placed.
This statement retrieves additional information about the web server and the current browser request. This statement only works on Panorama X Server, and only when an external web server is being used (see Using an External Web Server). For example, this code could be used to find out what external web server software is running:
local serverSoftware
webserverinfo "SERVER_SOFTWARE",serverSoftware
// variable serverSoftware will contain something like --> Apache/2.4.48 (Unix)
The webserverinfo( function can also retrieve the same information, like this:
let serverSoftware = webserverinfo("SERVER_SOFTWARE")
The available items that can be retrieved include:
QUERY_STRING – The information (if any) following the “?” in the URL for this request (for example ColoradoHotels~byCity~Aspen
SERVER_SOFTWARE – The name and version of the information server answering the query (for example Apache/2.4.48 (Unix)
SERVER_ADDR – The IP address of the server for this URL (for example 207.35.76.24
SERVER_ADMIN – The administrators e-mail address for this server (if it has been set up. (for example webmaster@myserver.org
SERVER_NAME – The servers host name, DNS alias or IP address. (For Apache the name appearing on the relevant ServerName directive (may be in the general sec- tion or a section) (for example `www.myserver.com)`).
SERVER_PORT – The port number on this server to which this request was directed (for example 80
SERVER_SIGNATURE – The HTML string that may be embedded in the page to identify this host (for example Apache/1.3.29 Server at jim-reas- computer.local Port 80
SERVER_PORT – The port to which this request was directed (for example 80
REMOTE_ADDR – The IP address of the host making this request (for example 207.35.76.27
REMOTE_PORT – The port number used by the remote host when making this request (for example 4325
REQUEST_METHOD – The method used for this request for HTTP “GET”, HEAD" or “POST” (for example GET
HTTP_ACCEPT – The MIME types the requestor will accept as defined in the HTTP header (for example * / *
HTTP_ACCEPT_ENCODING – The compression types the requestor will accept as defined in the HTTP header (for example gzip, deflate;q=1.0, identity;q=0.5, *;q=0
HTTP_ACCEPT_LANGUAGE – The LANGUAGE types the server is requested to accept as defined in the HTTP header and typically used for content negotiation (for example en-us
HTTP_CONNECTION – The type of connection as defined in the HTTP header (for example keep-alive
HTTP_HOST – The base URL of the host (for example www.myserver.com
HTTP_REFERER – The URL of the page that made this request. If linked from e-mail or manually entered this value is NULL. (Depending on your server settings this may be disabled, in which case the value will always be NULL. Also, many browsers are removing or limiting the information provided by this item.) (for example http://www.samplesite.com/ stuff.html
HTTP_USER_AGENT – The browser id or user-agent string identifying the browser (nominally defined by RFC 1945 and RFC 2068). For a list of current browsers see: http:// www.zytrax.com/tech/web/browser_ids.htm (for example Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko)
Note: Some of these options may not be available on all servers.
- cgilink( -- creates a domain independent URL for another CGI action on the same server.
- cgilinknewwindow( -- creates a domain independent link for another CGI action on the same server that opens a new browser window.
- cginavlink( -- creates a domain-independent navigation link for the current record in this database.
- cginavlinknewwindow( -- creates a domain-independent navigation link (to a new browser window) for the current record in this database.
- HTML Export -- custom exports into an HTML file.
- htmldecode( -- converts HTML text into regular text by converting any special HTML entities (`&`, `©`, etc.) into the corresponding characters.
- htmlencode( -- converts standard text into HTML text by converting any special characters into the equivalent HTML entities.
- htmlextractimages -- extracts the image URLs from an HTML page.
- htmlextractlinks -- extracts the links from an HTML page.
- htmlformitemnames -- returns a list of form input elements (*INPUT* tags, etc.) within an HTML page.
- Web Cookies -- web cookies.
- webformlink( -- generates a link to a Panorama form on the current web site (the link will open in a new browser window).
- webformlinknewwindow( -- generates a link to a Panorama form on the current web site.
- weblink( -- builds an HTML link tag
- weblinknewwindow( -- builds an HTML link tag
10.2 | Updated | Carried over from Panorama 6. |
