settagparameter
TAGLIST
TAG
VALUE
The settagparameter statement sets the value of a tag parameter in a list of tag parameters.
taglist – Field or variable that contains the list of tag parameters
tag – Tag parameter name
value – New value for tag parameter
This statement sets the value of a tag parameter in a list of tag parameters.
For example, suppose you have a variable named options that contains a number of values in this format:
width=500
height=200
color=Gold
priority=High
To change the height parameter, use this statement.
settagparameter options,"height=","120"
If a value doesn’t already exist, it will be added at the end of the list.
settagparameter options,"weight=","24"
Here is the final value of the options variable after these two modifications.
width=500
height=120
color=Gold
priority=High
weight=24
