selectallobjects
The selectallobjects statement selects all the graphic objects in the current form.
The selectallobjects statement will select all the graphic objects in the current form. (This is the same concept as going into graphics mode and choosing the Select All menu command.) After the objects are selected you can get information about them or change the attributes of certain objects. In other words, you can change forms on the fly.
This example will reduce the brightness of every object in the form by 20%.
selectallobjects
changeobjects "color",hsb(
hue( objectinfo("color") ),
saturation( objectinfo("color") ),
0.8*brightness( objectinfo("color") ))
selectnoobjects
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
