runningdifference
The runningdifference statement calculates the running difference for the current field.
The runningdifference statement starts at the top of the database and subtracts each cell from the cell above it. As it scans the database it fills the field with the running total, destroying the original data in the process.
This example calculates the gas mileage after each fillup. Since the runningdifference statement will destroy the field it is used on, the procedure copies the Odometer data into a separate field called Miles. The runningdifference statement computes the number of miles driven on a tank of gas (the difference between the two odometer readings).
field Miles
formulafill Odometer
runningdifference
field Mileage
formulafill Miles/Gallons
- @calculations --
- runmodifyfill -- runs the .ModifyFill procedure (if it exists).
- slidedata -- slides the columns at and to the right of the current column.
