The comparedictprocedures statement compares all the procedures from a dictionary with the procedures in a specified database.
This statement has five parameters:database – Name of the database, or “” for current database.
dictionary – Dictionary (built with the saveallprocedures statement)
modified – Field or variable to receive a carriage return delimited list of procedures that exist in both places but are not identical.
new – Field or variable to receive a carriage return delimited list of procedures that exist in the dictionary but not in the database.
removed – Field or variable to receive a carriage return delimited list of procedures that exist in the database but not in the dictionary.
This statement compares all the procedures from a dictionary with the procedures in a specified database. It returns information about how the two lists differ.
Here is an example that saves a copy of all procedures in the current database into a global variable.
global psave
saveallprocedures psave
Here is a second example that can be run later to find out which procedures have been modified.
local mp,np,rp
comparedictprocedures "",psave,mp,np,rp
displaydata
"Modified:"+cr()+cr()+mp+cr()+cr()+
"New:"+cr()+cr()+np+cr()+cr()+
"Removed:"+cr()+cr()+rp
Note: Starting with Panorama X, you can use the File>Export>Blueprint feature and check the database blueprint into a git repository (or other svn). This allows you to track changes made to procedures (and other database elements) through the source version control system.
