popupdoublefieldchoices
CHOICE
PRIMARYFIELD
SECONDARYFIELD
INITIAL
SELECTED
The popupdoublefieldchoices statement displays a pop-up menu listing values in a specified field, with submenus containing values from a second field.
This statement has five  parameters:
choice – field or variable where the final user choice will be placed (or "" will be placed if no menu item was chosen). This field or variable will contain two values separated by a period, the choice from the primary menu and the submenu.
primaryfield – Field that contains data to be listed as choices in the main pop-up menu.
secondaryfield – Field that contains data to be listed as choices in submenus.
initial – Initial choice to be selected in main pop-up menu (or “” if no choice).
selected – This optional parameter specifies whether the values used to build the pop-up menus should be pulled from all records or only selected records. If this parameter is blank or omitted, all records will be used. Procedure will use selected records only if any other value is in this parameter.
This statement can be used to produce a pop-up menu in response to clicking on a button. Instead of specifying the items in the menu, the items are automatically gathered from the specified field. The items will be displayed in alphabetical order.
The menu will pop-up over the button that was pressed. It is intended that this statement be used in a procedure that is triggered by a button on a form (or any form object that triggers a procedure). The procedure must be triggered on mouse down, not mouse up.
Suppose your database contains fields named Category and PayTo. This example will automatically pop-up a menu listing all of the categories in the database. Each menu item will have a submenu attached to it that lists the actual entities that have been paired in each category.
local myChoice,myCategory,myPayTo
popupdoublefieldchoices myChoice,Category,PayTo,""
myCategory=array(myChoice,1,".")
myPayTo=array(myChoice,2,".")
- Action Menu -- simple way to create your own menu items.
- arraymenuitems( -- converts a carriage return delimited array into a series of menu items.
- checkedarraymenuitems( -- converts a carriage return delimited array into a series of menu items, some of which may be checked.
- checkedmenuitem( -- creates a single menu item with an optional checkmark.
- Construct Menu -- used to automatically construct complex form applications, including calendars, lists, mailing labels, and more.
- Edit Menu -- edit text and data, to search (and replace), and to undo and recent actions.
- Field Menu -- manages fields, including adding and removing fields, setting field properties, sorting, morphing, hiding and showing.
- File Menu -- create, locate, open, close and save databases, import and export text, printing.
- filemenubar -- creates a custom menu bar or context menu for the current database (see Custom Menus).
- globalmenubar -- creates a custom menu bar or context menu for all windows (intended only for internal use by ProVUE Development).
- Help Menu -- contains items that will help you learn and use Panorama.
- LMSL -- is the specification language for Live Menus.
- menu( -- creates a menu (see Custom Menus).
- menuitem( -- creates a single menu item (see Custom Menus).
- menuitems( -- converts a semicolon separated array into a live menu specification.
- Menus -- overview of Panorama X menu bars.
- menuseparator( -- generates a menu item separator
- noactionmenu( -- suppresses the *Action* menu.
- noinstrumentationmenu( -- supresses the *Instrumentation* menu.
- nowizardmenu( -- suppresses the *Wizards* menu.
- Objects Menu -- used to select, modify and arrange graphics objects in a form.
- Panorama Menu -- get and set information about Panorama itself, including the version number, licensing information, and memory usage.
- popup -- makes a pop-up menu appear anywhere on the screen.
- Popup Menu Button Object -- is used to create popup menus anywhere on a form.
- popupatmouse -- displays a pop-up menu at the current mouse location.
- popupbelowbutton -- displays a pop-up menu in response to clicking on a button.
- popupbynumber -- makes a pop-up menu appear anywhere on the screen.
- popupclick -- displays a pop-up menu at the current mouse location.
- popupfieldchoices -- displays a pop-up menu listing values in a specified field.
- Records Menu -- add and remove database records.
- Search Menu -- is used search for data, to select records, and to find and replace text within the current field.
- standardactionmenu( -- generates a Custom Menu specification for Panorama's standard Action menu.
- standardclassicsetupmenu( -- generates a customizable Custom Menu specification for Panorama's classic Setup menu.
- standardconstructgraphicsmenu( -- generates a Custom Menu specification for Panorama’s standard Construct menu (in Graphics Mode).
- standardeditmenu( -- generates a customizable Custom Menu specification for Panorama's standard Edit menu.
- standardfieldsmenu( -- generates a customizable Custom Menu specification for Panorama's standard Fields menu.
- standardfilemenu( -- generates a customizable Custom Menu specification for Panorama's standard File menu.
- standardhelpmenu( -- generates a customizable Custom Menu specification for Panorama's standard Help menu.
- standardinstrumentationmenu( -- generates a Custom Menu specification for Panorama’s standard Instrumentation menu.
- standardpanoramamenu( -- generates a Custom Menu specification for Panorama's standard Panorama menu.
- standardrecordsmenu( -- generates a customizable Custom Menu specification for Panorama's standard Records menu.
- standardsearchmenu( -- generates a customizable Custom Menu specification for Panorama's standard Search menu.
- standardsetupmenu( -- generates a customizable Custom Menu specification for Panorama's standard Setup menu.
- standardsortmenu( -- generates a customizable Custom Menu specification for Panorama's standard Sort menu.
- standardtextmenu( -- generates a customizable Custom Menu specification for Panorama's standard Text menu.
- standardviewmenu( -- generates a Custom Menu specification for Panorama's standard View menu.
- standardwindowmenu( -- generates a customizable Custom Menu specification for Panorama's standard Window menu.
- submenu( -- creates a submenu (see Custom Menus).
- Window Menu -- controls the back to front arrangement of windows, it allows you to hide, show, or customize the toolbar (see Toolbar, and allows you minimize or zoom the window to full screen.
- windowmenubar -- creates a custom menu bar or context menu for the current window (see Custom Menus).
