downloadrecordwithwarning
The downloadrecordwithwarning statement downloads the current record from the connected server, with a warning if the record is currently locked.
This statement downloads the current record from the connected server, with a warning if the record had been locked by this computer. If the users asks to proceed past the warning, the record is unlocked, so that all edits performed since locking the record are cancelled.
Note: This statement is identical to the downloadrecord statement, except that the downloadrecord statement always proceeds without any warning. Also, the downloadrecordwithwarning statement displays a notification when the download operation is complete.
- Web Cookies -- web cookies.
10.2 | Updated | New in this version. |
