resumeaftertask
TASKID
The resumeaftertask statement resumes after a waitfortask statement.
taskid – the ID of the task to wait for (either a timer or a urltask().
This statement resumes after a waitfortask statement. See the waitfortask documentation to learn how to use this statement.
- info("computername") -- returns the name of the computer (as set up in the System Preferences Sharing panel).
- quit -- quits Panorama.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerexists( -- checks to see whether a timer exists.
- Timers -- executing recurring periodic background code at fixed intervals.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
