throwerror
MESSAGE
The throwerror statement causes an immediate error.
message – is the error message.
This statement causes an immediate error. If this happens while a try/catch block is active, control flow will jump to the first statement after the catch statement. See Error Handling.
- catcherror( -- evaluates an expression, but suppresses any error generated by that expression.
- error( -- returns an error with the specified message.
- errortext( -- evaluates an expression, but returns only the error message generated (if any).
