arraynumerictotal
INPUTARRAY
SEP
NUMERICTOTAL
The arraynumerictotal statement totals all the numeric elements of a text array.
inputarray – The original numeric text array.
sep – The separator character or characters used in this array.
numerictotal – The field or variable that will hold the total value of all the numeric array elements.
This statement totals all the numeric elements of a text array. Here is an example that will add up the values of all the elements in the array GroupMembers and assigns the total value to the variable GroupTotal.
local GroupMembers, GroupTotal
GroupMembers = "14 52 83 22 91 5 44 182 64"
arraynumerictotal GroupMembers," ",GroupTotal
message GroupTotal
The message will be 557.
10.0 | Updated | Carried over from Panorama 6.0 but more than one character is now allowed for use as the separator parameter |
