automaticfieldchoices
The automaticfieldchoices statement updates the current field’s Choice list with actual data in the database.
This statement updates the current field’s Choice list with actual data in the database. It is triggered by pressing the Automatic Choice List button in the Field Properties Panel.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
