changetimer
NAME
PROPERTY
VALUE
The changetimer statement modifies a repeating task that will be performed periodically when Panorama is not otherwise busy.
name – specifies the periodic task to be modified. The task must have already been set up with the starttimer statement.
property – a timer property. Each timer has properties including the task to be run, the interval, etc. See below for detailed descriptions of the different timer properties available. Properties can be specified in either upper or lower case, for example INTERVAL or interval.
value – the new value for the property specified by the previous parameter.
This statement modifies a repeating task that was previously set up with the starttimer statement. For example, this code will modify the beat timer so that it performs its task every other second.
changetimer "beat","interval",2
Timer Properties
Each timer has multiple properties – how often the timer runs, what code is used to perform the timer’s task, whether or not the timer runs in the background, etc. When you modify a timer, you can specify all the properties you need, like this:
changetimer name,property1,value1,property2,value2,property3,value3
For complete descriptions of the timer properties available, see the starttimer statement.
- info("computername") -- returns the name of the computer (as set up in the System Preferences Sharing panel).
- info("timers") -- returns a carriage return separated list of all active timers.
- stoptimer -- stops and deletes a timer that was set up with the StartTimer statement.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerexists( -- checks to see whether a timer exists.
- timerinfo( -- returns a dictionary that contains all of the properties of a timer.
- Timers -- executing recurring periodic background code at fixed intervals.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
