downrecord
The downrecord statement moves the cursor down one visible record.
The downrecord statement moves down one record in the current database. If the currently active record is already the last record in the database this statement will do nothing (you can check whether this happened with the info(“stopped”) function.
- field -- tells Panorama to move to the specified field for the current record.
