selectreverse
The selectreverse statement makes every visible record invisible, and every invisible record visible.
This statement reverses the unselected (or invisible) and selected (or visible) records in a database. For example, if a database has 10 records and 3 are selected prior to doing a selectreverse, afterwards 7 records will be selected and 3 will be unselected. This example selects all records that are NOT in California.
select State="CA"
selectreverse
Note: Of course the same effect could be achieved with the statement
select State<>"CA"
However, the selectreverse statement is useful when you do not know how the current selection was arrived at.
Since there must be at least one visible record in a Panorama database at all times, the selectreverse statement has no effect if all records are selected.
