The for statement is used at the beginning of a loop that loops a fixed number of times.
This statement has three parameters:variable – is the name of a field or variable where the loop count will be stored. If this field or variable does not already exist it will be created as a local variable.
start – is the starting value of the loop. This value is calculated once before the loop starts, it cannot change once the loop begins running.
end – is the ending value of the loop. This value is calculated once before the loop starts, it cannot change once the loop begins running.
The for statement is used at the beginning of a loop that iterates a fixed number of times (see the loop statement for more information about loops). For loops are always terminated with an endloop statement.
The first parameter of the for statement is the name of a field or variable. This field or variable will contain the start value when the loop begins. It will then be incremented by 1 at the start of each repetition. After the loop has finished, this field or variable will contain the end value.
This simple example adds 10 new records to the current database. The Sequence field will contain a number from 1 to 10 (1 in the first record added, 10 in the last record added).
for i,1,10
addrecord
Sequence=i
endloop
The loop does not have to begin with 1 – it can begin with any positive integer value (negative values are not allowed).
for i,11,20
addrecord
Sequence=i
endloop
The start and end values can be calculated with formulas, like this:
local start,count
start=101
count=100
for i,start,start+count-1
addrecord
Sequence=i
endloop
Keep in mind that these formulas are calculated only once when the loop starts. In this silly example the count value changes inside the loop. In spite of this, the loop will always run 100 times, not 50 or 51.
local start,count
start=101
count=100
addrecord
Sequence=i
count=50
endloop
Daspite the fact that the count variable was set to 50 during the loop, it’s value will always be set to the value of the internal counter at the head of each loop, and on completion. In the eaxample above, the count variable will have a value of 101 at the start. It will be 102 on the next repetition, and so on. It’s value at the finish will be 200, despite the fact that the variable was set to 50 at the end of the last repetition.
You can nest one for loop inside another. If you do, you will probably want to use a different variable for each of the loops. (Advanced tip: The loops will still work if the same variable is used for multiple nested loops, but the variable may not always contain the value you expect.)
local multiplicationTable
multiplicationTable =""
for i,1,10
for j,1,10
multiplicationTable=multiplicationTable+cr()+str(i)+"*"+str(j)+"="+str(i*j)
endloop
endloop
message multiplicationTable
Error Messages
LOOP without ENDLOOP – Each FOR statement must be paired with a corresponding ENDLOOP, UNTIL or WHILE statement. If this error message appears, the necessary statement terminating the loop has not been included.
| Version | Status | Notes |
| 10.0 | New | New in this version |
